跳转到主内容
DeWalt DC970 Battery Fuse Replacement
你所需要的
  1. DeWalt DC970 Battery Fuse Replacement, Battery Fuse: 步骤 1 中的图像 1,2 DeWalt DC970 Battery Fuse Replacement, Battery Fuse: 步骤 1 中的图像 2,2
    • Remove the four 13 mm, Torx Security #15 screws found on the bottom of the charger.
  2. DeWalt DC970 Battery Fuse Replacement: 步骤 2 中的图像 1,2 DeWalt DC970 Battery Fuse Replacement: 步骤 2 中的图像 2,2
    • Remove the 19 mm, Torx Security #10 screw found in the charger port.
    • Then pull the top of the charger off separating it from the bottom.
  3. DeWalt DC970 Battery Fuse Replacement: 步骤 3 中的图像 1,1
    • Locate the fuse and pull it out with two fingers.
    • Once you have located the fuse, if you have the replacement fuse just pull the old one out and put the new one in.
    • Replacement fuses can be found in hardware stores.
结论
4等其他人完成本指南。
团队
UMass Dartmouth, Team 4-2, Catania Spring 2016 UMass Dartmouth, Team 4-2, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G2
3 名成员
创作了13篇指南
一条评论
Can i get some help in locating the fuse in mt dcb 112 dewalt battery charger i cant found it
bigboyf232 - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 38
过去 30 天: 252
总计 17,447
