简介
This guide will walk you through replacing the brush and spring components of the grinder. These are both located at the base of the brush motor and can be easily replaced.
你所需要的
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
即将完成!
结论
