跳转到主内容
简介
The DeWalt D26451 power switch turns the sander on and off. It may not be working because the circuit is out of alignment, there is a tripped breaker, or a stripped wire.
Replacing the power switch may fix your on/off issues. In this guide, we will be teaching you how to replace the switch. You can order a replacement switch here.
配件
  1. Please wear safety glasses while completing this guide.
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. Gently pry the cap off using your fingers or spudger tool.
    • Gently pry the cap off using your fingers or spudger tool.
  3. Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment.  Once the cord is loose, pull the connectors out
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. Apple Watch 套装
    Screen and battery repairs just got easier.
    现在开始购物
    Apple Watch 套装
    现在开始购物
  5. Loosen the white and black wire terminals
    • Loosen the white and black wire terminals
  6. Insert new power cord terminals and tighten down
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
  7. Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
    • Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
  8. Gently pry the cap off
  9. Once the cap is removed, the switch and connectors should be exposed
    • Once the cap is removed, the switch and connectors should be exposed
  10. Remove both connectors from the switch
    • Remove both connectors from the switch
结论
Shelby LeQuire
于2016年01月29日注册
588 信誉积分
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 11
总计 427
