跳转到主内容
DeWALT Hammer Drill DW511 Brush Spring Replacement
你所需要的
  1. DeWALT Hammer Drill DW511 Brush Spring Replacement, Back Cover: 步骤 1 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Spring Replacement, Back Cover: 步骤 1 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Spring Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 2 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 2 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 2 中的图像 3,3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Brush Spring Replacement, Power Cord: 步骤 3 中的图像 1,2 DeWALT Hammer Drill DW511 Brush Spring Replacement, Power Cord: 步骤 3 中的图像 2,2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 4 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 4 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 5 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 5 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 5 中的图像 3,3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Brush Spring Replacement: 步骤 6 中的图像 1,1
    • With both wires free, the power cord is free from the trigger body.
  7. DeWALT Hammer Drill DW511 Brush Spring Replacement, Brush Spring: 步骤 7 中的图像 1,2 DeWALT Hammer Drill DW511 Brush Spring Replacement, Brush Spring: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • With broad-tipped tweezers, grab the bottom flap of the metal spring.
    • Pull the flap up and proceed to pull off the spring.
    • Be careful pulling the spring off; it is easy to break and lose.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 311
