跳转到主内容
DeWALT Hammer Drill DW511 Brush Replacement
你所需要的
  1. DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: 步骤 1 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: 步骤 1 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Brush Replacement: 步骤 2 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Replacement: 步骤 2 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Replacement: 步骤 2 中的图像 3,3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Brush Replacement, Power Cord: 步骤 3 中的图像 1,2 DeWALT Hammer Drill DW511 Brush Replacement, Power Cord: 步骤 3 中的图像 2,2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Brush Replacement: 步骤 4 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Replacement: 步骤 4 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Brush Replacement: 步骤 5 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Replacement: 步骤 5 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Replacement: 步骤 5 中的图像 3,3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Brush Replacement: 步骤 6 中的图像 1,1
    • With both wires free, the power cord is free from the trigger body.
  7. DeWALT Hammer Drill DW511 Brush Replacement, Brushes: 步骤 7 中的图像 1,3 DeWALT Hammer Drill DW511 Brush Replacement, Brushes: 步骤 7 中的图像 2,3 DeWALT Hammer Drill DW511 Brush Replacement, Brushes: 步骤 7 中的图像 3,3
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. DeWALT Hammer Drill DW511 Brush Replacement: 步骤 8 中的图像 1,2 DeWALT Hammer Drill DW511 Brush Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • With a pair of blunt nose tweezers, grab the red wire.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 1,110
