你所需要的
Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
Unscrew the two Phillips screws
The Phillips screw under the water tank can remain.
The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
Some devices have a warming plate. Disconnect the flat plugs on the green/yellow protective earth conductors.
Work through the steps in reverse order to reassemble your device.
由衷感谢以下译者:
100%
shingle正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
