跳转到主内容
DeLonghi ESAM 3000.B Magnifica disassembling
你所需要的
  1. DeLonghi ESAM 3000.B Magnifica disassembling, Preparations: 步骤 1 中的图像 1,1
    • Pull the plug!
    • Remove the drip tray, the water tank and the pulp container.
  2. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: 步骤 2 中的图像 1,2 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: 步骤 2 中的图像 2,2
    • The rear panel and side panels are attached with six phillips screws #2. Screw them out.
  3. DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: 步骤 3 中的图像 1,2 DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: 步骤 3 中的图像 2,2
    • Slide the right side panel about 2 cm to the back.
    • Then solve it.
  4. DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: 步骤 4 中的图像 1,3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: 步骤 4 中的图像 2,3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: 步骤 4 中的图像 3,3
    • The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
    • Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
    • Lift out the left side piece.
  5. DeLonghi ESAM 3000.B Magnifica disassembling, Remove rear panel: 步骤 5 中的图像 1,1
    • Take out the rear panel.
  6. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: 步骤 6 中的图像 1,3 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: 步骤 6 中的图像 2,3 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: 步骤 6 中的图像 3,3
    • The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
    • Use a plastic opening tool to lever off the steam tap.
    • Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
    • Do not pull the front panel too far, it is still attached with different hoses and cables.
  7. DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: 步骤 7 中的图像 1,3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: 步骤 7 中的图像 2,3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: 步骤 7 中的图像 3,3
    • Two Phillips screws PH2 hold the lid at the back. Turn it out.
    • Lift the lid upwards.
结论
Follow the steps in reverse order to reassemble your device.
15等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
297,205 声望
创作了303篇指南
4指南评论
Bonjour et merci pour le partage;
Comment démonter le panneau de commandes à l’avant svp, il semblerait que le bouton rond qui permet de régler la quantité d’eau par tasse ne répond plus normalement. En effet en choisissant une double tasse et en ayant tourner ce bouton au maximum pour la quantité de café par tasse, j’obtiens un tiers de bol…ce bouton se serait il décalé??? ou est ce plutôt un autre problème? avez vous une idée svp? Merci d’avance pour vos réponses.
Laurence MUNSCH - 回复
Le régulateur réagit-il ? Si vous le retournez, est-ce qu'il produit aussi moins de café ? Il existe de nombreuses possibilités : le débitmètre, la pompe, le piston supérieur…
VauWeh -
Bonjour j ai le bouton service toujours allumé. Pas détartrage mais je pense un problème électrique.
Qq peux m aider merci
yacoub bouanene - 回复
Utilisez le mode test pour trouver une solution. C'est en allemand, traduisez avec Google Translate.
VauWeh -
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 107
过去 30 天: 407
总计 26,244
