跳转到主内容
DeLonghi ESAM xxxx Solenoid Replacement
你所需要的
  1. DeLonghi ESAM  xxxx Solenoid Replacement, Solenoid: 步骤 1 中的图像 1,1
    • Before you begin: UNPLUG! Remember not to touch current leading parts, if plugged in.
  2. DeLonghi ESAM  xxxx Solenoid Replacement, Open the machine: 步骤 2 中的图像 1,3 DeLonghi ESAM  xxxx Solenoid Replacement, Open the machine: 步骤 2 中的图像 2,3 DeLonghi ESAM  xxxx Solenoid Replacement, Open the machine: 步骤 2 中的图像 3,3
    • Rearside: unscrew two screws, push upside.
    • Side covers: unscrew two screws, push backwards.
    • Top: unscrew four screws, disassemble the adjuster of the grinder as shown in step 3
  3. DeLonghi ESAM  xxxx Solenoid Replacement, Adjuster: 步骤 3 中的图像 1,3 DeLonghi ESAM  xxxx Solenoid Replacement, Adjuster: 步骤 3 中的图像 2,3 DeLonghi ESAM  xxxx Solenoid Replacement, Adjuster: 步骤 3 中的图像 3,3
    • Remove the cap, then unscrew the exposed screw. Take away the adjuster.
    • Now you can remove the top of the machine.
  4. DeLonghi ESAM  xxxx Solenoid Replacement, The Solenoid Valve: 步骤 4 中的图像 1,2 DeLonghi ESAM  xxxx Solenoid Replacement, The Solenoid Valve: 步骤 4 中的图像 2,2
    • Now plug in and try to get a cup of coffee but CAUTION, don´t touch anything, high voltage.
    • On top of the boiler you can see the valve. Can you see if the water really drips out of the valve? Pull the plug!
  5. DeLonghi ESAM  xxxx Solenoid Replacement, Old and new: 步骤 5 中的图像 1,2 DeLonghi ESAM  xxxx Solenoid Replacement, Old and new: 步骤 5 中的图像 2,2
    • Of course buy a new one at a DeLonghi supplier. The old one normally has a metal body, the new one plastic. That provokes some problems. You also need raccords for directions in- and out. The outgoing one is double, but there may be differences. In the photo they are already assembled.
    • Attention! The valve has a direction. The sense of the flew is towards the black point. The double raccord must be there!
  6. DeLonghi ESAM  xxxx Solenoid Replacement, Changing 1: 步骤 6 中的图像 1,3 DeLonghi ESAM  xxxx Solenoid Replacement, Changing 1: 步骤 6 中的图像 2,3 DeLonghi ESAM  xxxx Solenoid Replacement, Changing 1: 步骤 6 中的图像 3,3
    • The boiler and valve are fixed with three screws. Also loosen some cables and hoses until the boiler can be removed.
  7. DeLonghi ESAM  xxxx Solenoid Replacement, Changing 2: 步骤 7 中的图像 1,3 DeLonghi ESAM  xxxx Solenoid Replacement, Changing 2: 步骤 7 中的图像 2,3 DeLonghi ESAM  xxxx Solenoid Replacement, Changing 2: 步骤 7 中的图像 3,3
    • Two screws hold the valve looking upwards.
    • As the old one uses M4 screws you have to cut the thread into the plastic body. Use a threader.
    • and make a circle cut into the plastic of the holder of the boiler in order to let the incoming hose pass by.
  8. DeLonghi ESAM  xxxx Solenoid Replacement, Finito!: 步骤 8 中的图像 1,1
    • Hopefully you can get a cup of coffee! Then reassemble all parts.
结论
Have a cup of coffee!
4等其他人完成本指南。
VauWeh
于10/19/15注册
212,879 声望
创作了265篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
27 名成员
创作了1,209篇指南
3条评论
Superb,thank you very much !!!
Vedrasco Victor Vasili - 回复
This guide helped me tremendously with the repair of my Delonghi Magnifica which is very similar. In particular, the explanation of the difference between the old and new solenoids, and the need for new raccords (a new word to me!) was helpful, although I’ve yet to figure out where to get the raccords from.
I fitted a new pump, flow meter, and will be fitting a new solenoid when I get the relevant parts.
Alan Shilling - 回复
Glad to help you. Maybe the above mentioned German dealer is shipping?
VauWeh -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 40
过去 30 天: 168
总计 17,316
