跳转到主内容
DeLonghi ESAM xxxx - Test Mode
  1. DeLonghi ESAM  xxxx - Test Mode, Activate Test Mode: 步骤 1 中的图像 1,2 DeLonghi ESAM  xxxx - Test Mode, Activate Test Mode: 步骤 1 中的图像 2,2
    • Pull the plug. Switch on rear side is in position "On".
    • Press and hold both keys for "one cup" and "steam".
    • Reconnect the plug.
    • LEDs light up. When they are off again, the machine is in test mode. Release the two keys.
    • If there is no water in the reservoir or not all drawers are inserted correctly, corresponding LEDs will light up.
  2. DeLonghi ESAM  xxxx - Test Mode, Motor Test: 步骤 2 中的图像 1,2 DeLonghi ESAM  xxxx - Test Mode, Motor Test: 步骤 2 中的图像 2,2
    • Press the key "one cup". The motor should drive down. If it reaches the lower end position the correspondending LED will light up.
    • Press the key two cups". The motor should drive upwards. If it reaches the upper end position the correspondending LED will light up.
    • Tip: the brewing unit has to be in the right start position for correct function. It's a good idea to take a foto or mark the position.
    • If the lower four LEDs light up in sequence during later operation, the start position has not yet been set correctly. Take out the brewing unit and close the service door. Press the "one cup" and "two cups" buttons simultaneously, the motor will automatically search for the right position. Put the brewing unit back in.
  3. DeLonghi ESAM  xxxx - Test Mode, Pump Test: 步骤 3 中的图像 1,1
    • Press the "steam" key. The pump should be activated. If the steam wand is opened the water should flow.
  4. DeLonghi ESAM  xxxx - Test Mode, Grinder Test: 步骤 4 中的图像 1,1
    • Press the "ECO" key. The grinder should be activated.
  5. DeLonghi ESAM  xxxx - Test Mode, Heater Test: 步骤 5 中的图像 1,1
    • Press the "Rinse" key. One LED should light up and the heater should be activated. If it reaches the end temperature, the LED goes out.
  6. DeLonghi ESAM  xxxx - Test Mode: 步骤 6 中的图像 1,1
    • Pull the plug again to leave the test mode.
结论
另外一个人完成了本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
297,290 声望
创作了303篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 81
过去 30 天: 350
总计 18,567
