简介
This guide requires you to fully take apart the device. Be careful not to misplace any parts once you have removed them. This guide would be used if your coffee maker has no water flow.
你所需要的
Flip open the top panel to reveal water reservoir.
Grab the water reservoir by the handle and lift out.
Flip the device on its head.
Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
Lift the panel off or flip the device over and let the panel drop out.
Flip the device on its head, front end facing you.
Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
Remove both sets of wires from the black box.
Remove the filter attached to the bottom of the pump.
6等其他人完成本指南。
4条评论
I was trying to remove the valve. I am not sure what axis to turn it on. Also how do I know if the valve is bad or the pump, or both?
Just get both parts. I think the valve is only a few dollars. The only moving part is the pump and that is by far the most likely problem.
shadowym -
Are you still taking feedback?
Die Schrauben auf der Bodenplatte sind nicht wie angegeben Kreuzschrauben sondern Safety Tamper Proof Star 6 Point.
