跳转到主内容
Datawind Ubislate 7ci Speaker Replacement
你所需要的
  1. Datawind Ubislate 7ci Speaker Replacement, Finding a workspace: 步骤 1 中的图像 1,1
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: 步骤 2 中的图像 1,2 Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: 步骤 2 中的图像 2,2
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Datawind Ubislate 7ci Speaker Replacement, Removing the speaker: 步骤 3 中的图像 1,1
    • Use your prying tool to pop the speaker out from its housing.
  4. Datawind Ubislate 7ci Speaker Replacement, Detach from contact points: 步骤 4 中的图像 1,1
    • Use a soldering iron to remove the speaker from its contact points.
  5. Datawind Ubislate 7ci Speaker Replacement, Attaching replacement to contact points: 步骤 5 中的图像 1,1
    • Solder your new speaker to the same contact points as before.
  6. Datawind Ubislate 7ci Speaker Replacement, Housing the replacement speaker: 步骤 6 中的图像 1,1
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  7. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: 步骤 7 中的图像 1,2 Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: 步骤 7 中的图像 2,2
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
结论
另外一个人完成了本指南。
Mekides
于10/20/14注册
40 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G3
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 355
