跳转到主内容
Daisy Model 10 Carbine Cocking Lever Replacement
你所需要的
  1. Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: 步骤 1 中的图像 1,3 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: 步骤 1 中的图像 2,3 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: 步骤 1 中的图像 3,3
    • Make sure the safety is on!
    • Place the carbine with the saddle ring and leather thong facing upwards.
    • Locate the screw head on the cocking lever.
    • There should be one on either side of the saddle ring and one on the cocking lever assembly.
    • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
    • Completely remove the screws.
    • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
  2. Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: 步骤 2 中的图像 1,2 Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: 步骤 2 中的图像 2,2
    • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
    • With your fingers in the handle, slide the lever towards the butt of the carbine.
    • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
结论
Timothy Gachot
于10/12/14注册
237 声望
创作了2篇指南
团队
Cal Poly, Team 6-20, Maness Fall 2014 Cal Poly, Team 6-20, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G20
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 2,418
