简介
To repair your cocking lever you will need a Phillips 2 screwdriver. In addition to this, this manual requires you to remove a small screw and washer from the carbine. To avoid losing these, replace your cocking lever on a table or similar workspace.
你所需要的
Place the carbine with the saddle ring and leather thong facing upwards.
Locate the screw head on the cocking lever.
Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
Completely remove the screws.
Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
With your fingers in the handle, slide the lever towards the butt of the carbine.
Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
