跳转到主内容
DYMO LabelWriter 450 Eject Button Replacement
你所需要的
  1. DYMO LabelWriter 450 Eject Button Replacement, Back Plate: 步骤 1 中的图像 1,3 DYMO LabelWriter 450 Eject Button Replacement, Back Plate: 步骤 1 中的图像 2,3 DYMO LabelWriter 450 Eject Button Replacement, Back Plate: 步骤 1 中的图像 3,3
    • Make sure the device is unplugged. Then, turn over the device so that the label is readable.
    • Remove the two 15.7mm screws on the top of the device first, and then the two 26.5mm screws on the bottom (they are in the smaller holes and larger holes respectively) using a Phillips #1 screwdriver.
    • You need a spudger to orient the bottom screws so that they can be removed.
  2. DYMO LabelWriter 450 Eject Button Replacement: 步骤 2 中的图像 1,2 DYMO LabelWriter 450 Eject Button Replacement: 步骤 2 中的图像 2,2
    • Once the Back Plate has been unscrewed, you will see the components from the top of the device plugged into the motherboard. You will only have 1-2 inches of clearance to unplug the components from the motherboard.
    • There are four components to unplug: the power cable connector, the two small no-fuss ribbon cable connectors, and the large no-fuss ribbon cable connector. The order does not matter.
    • This device has a blade located within the front panel. When handling the device, be careful not to touch the blade.
  3. DYMO LabelWriter 450 Eject Button Replacement, Eject Button: 步骤 3 中的图像 1,1
    • Turn the device upright and lift the lid. Carefully pull off the side panel that has the eject button on it until the panel gives way.
结论
另外一个人完成了本指南。
Jared Finkel
于10/09/18注册
649 声望
创作了5篇指南
团队
USF Tampa, Team S1-G4, Leahy Fall 2018 USF Tampa, Team S1-G4, Leahy Fall 2018 的会员
USFT-LEAHY-F18S1G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 26
总计 2,393
