跳转到主内容
DYMO LabelPOINT 100 Rubber Transport Roller Replacement
你所需要的
  1. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 步骤 1 中的图像 1,3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 步骤 1 中的图像 2,3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Slide the panel release button.
    • Lift the panel.
  2. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Label Tape Cassette: 步骤 2 中的图像 1,2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Label Tape Cassette: 步骤 2 中的图像 2,2
    • Firmly press the cartridge release button with your finger.
    • You may need to hold the cassette and/or entire device still while pressing the button.
    • Lift the label tape cassette out of the device.
  3. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 步骤 3 中的图像 1,3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 步骤 3 中的图像 2,3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Screws To the Acess Panel: 步骤 3 中的图像 3,3
    • Use Phillips #00 screwdriver to remove three screws
    • Remove blade cutter
    • Use Phillips #00 screwdriver to remove remaining two screws from the battery compartment
  4. DYMO LabelPOINT 100 Rubber Transport Roller Replacement: 步骤 4 中的图像 1,2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement: 步骤 4 中的图像 2,2
    • Gently pull the access panel up to separate from the device
    • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
  5. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 步骤 5 中的图像 1,3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 步骤 5 中的图像 2,3 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Back Panel: 步骤 5 中的图像 3,3
    • Use Phillips #00 screwdriver to remove six screws
    • Slowly separate back panel
    • Gears attached to the back panel are not secured and have a tendency to fall out. This will cause difficulty when reassembling
  6. DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Rubber Transport Roller: 步骤 6 中的图像 1,2 DYMO LabelPOINT 100 Rubber Transport Roller Replacement, Remove Rubber Transport Roller: 步骤 6 中的图像 2,2
    • Gently pull rubber transport roller up to remove
    • Replace rubber transport roller
结论
Deborah Canas
于09/25/14注册
122 声望
撰写一个指南
团队
USF Tampa, Team 5-2, Mcgee Fall 2014 USF Tampa, Team 5-2, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 1,251
