跳转到主内容
DYMO LabelPOINT 100 Keypad Replacement
你所需要的
  1. DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: 步骤 2 中的图像 1,2 DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: 步骤 2 中的图像 2,2
    • Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
    • Remove the blade cutter assembly.
    • Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
  2. DYMO LabelPOINT 100 Keypad Replacement, Remove Access Panel: 步骤 3 中的图像 1,1
    • Gently remove the access panel from the right side of the device.
    • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
  3. DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: 步骤 4 中的图像 1,2 DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: 步骤 4 中的图像 2,2
    • Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
    • Gently lift the bottom of the circuit board, revealing the keypad.
    • Be careful not to damage any components on the circuit board when disassembling.
  4. DYMO LabelPOINT 100 Keypad Replacement, Remove Keypad: 步骤 5 中的图像 1,1
    • Remove the keypad from the front facing cover
    • When installing the new keypad, make sure all buttons are correctly set in each hole so that each button can be pressed.
结论
Mike Dam
于09/25/14注册
201 声望
创作了2篇指南
团队
USF Tampa, Team 5-2, Mcgee Fall 2014 USF Tampa, Team 5-2, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,117
