跳转到主内容
DYMO LabelManager 160 Keyboard Replacement
你所需要的
  1. DYMO LabelManager 160 Keyboard Replacement, Batteries: 步骤 1 中的图像 1,1
    • Place the device face-down to access the battery compartment.
  2. DYMO LabelManager 160 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. DYMO LabelManager 160 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • To open the cartridge compartment, simply lift on the front of the device.
  4. DYMO LabelManager 160 Keyboard Replacement: 步骤 4 中的图像 1,2 DYMO LabelManager 160 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. DYMO LabelManager 160 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. DYMO LabelManager 160 Keyboard Replacement: 步骤 6 中的图像 1,3 DYMO LabelManager 160 Keyboard Replacement: 步骤 6 中的图像 2,3 DYMO LabelManager 160 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Gently remove the rubber keyboard from the device.
结论
2等其他人完成本指南。
3条评论
Group 9: Over all looks great. Screwdriver at top of page should be under tools not parts.
In Step 4 the screws in the second picture 2x 1.2mm should be circled in orange and should be a separate bullet with appropriate coloring.
Possibly add a picture using the spudger, so the user knows exactly where they need to pry.
Fantastic lighting and clear pictures!
Zachary Parker - 回复
Where do I get a replacement key boars
willow williams - 回复
Where did you obtain the parts from as I am having difficulty
Tommy Taylor - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 23
总计 1,819
