跳转到主内容
DROCON Ninja Casing Replacement
你所需要的
  1. DROCON Ninja Casing Replacement, Battery: 步骤 1 中的图像 1,3 DROCON Ninja Casing Replacement, Battery: 步骤 1 中的图像 2,3 DROCON Ninja Casing Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Casing Replacement, Casing: 步骤 2 中的图像 1,3 DROCON Ninja Casing Replacement, Casing: 步骤 2 中的图像 2,3 DROCON Ninja Casing Replacement, Casing: 步骤 2 中的图像 3,3
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Casing Replacement: 步骤 3 中的图像 1,2 DROCON Ninja Casing Replacement: 步骤 3 中的图像 2,2
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Casing Replacement: 步骤 4 中的图像 1,3 DROCON Ninja Casing Replacement: 步骤 4 中的图像 2,3 DROCON Ninja Casing Replacement: 步骤 4 中的图像 3,3
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 129
