跳转到主内容
DOSS SoundBox Speaker Replacement
你所需要的
  1. DOSS SoundBox Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 DOSS SoundBox Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. DOSS SoundBox Speaker Replacement: 步骤 2 中的图像 1,2 DOSS SoundBox Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  3. DOSS SoundBox Speaker Replacement: 步骤 3 中的图像 1,2 DOSS SoundBox Speaker Replacement: 步骤 3 中的图像 2,2
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
结论
To reassemble your device, follow instructions in reverse order.
2等其他人完成本指南。
1指南评论
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 47
总计 3,281
