跳转到主内容
DOSS SoundBox Base-plate Replacement
你所需要的
  1. DOSS SoundBox Base-plate Replacement, Base-plate: 步骤 1 中的图像 1,3 DOSS SoundBox Base-plate Replacement, Base-plate: 步骤 1 中的图像 2,3 DOSS SoundBox Base-plate Replacement, Base-plate: 步骤 1 中的图像 3,3
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Replacement: 步骤 2 中的图像 1,1
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Replacement: 步骤 3 中的图像 1,1
    • Lift the base-plate off of the enclosure.
结论
3等其他人完成本指南。
1指南评论
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 2,319
