跳转到主内容
加入维修社区 - 创建账户
DOPO 10.1 Tablet Dual .3 mega pixel Camera Replacement
你所需要的
  1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 步骤 1 中的图像 1,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 步骤 1 中的图像 2,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 步骤 1 中的图像 3,3
    • You will have to remove the back of the tablet. To do this, take the plastic opening tool, and insert into the side of the tablet and twist. This will pop off the side.
    • Slowly pull up on the cover until it is completely off.
    询问修复机器人
    添加评论
  2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 步骤 2 中的图像 1,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 步骤 2 中的图像 2,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 步骤 2 中的图像 3,3
    • You may notice that the battery is in the way. No worries, it is easy to move. All you will need to do is to gently lift up on the battery with a small constant pressure to release it from the adhesive.
    • Carefully put it off to the side.
    • Once the battery is removed you will see a gray wire. Lightly lift up, and move it out of way.
    询问修复机器人
    添加评论
  3. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 步骤 3 中的图像 1,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 步骤 3 中的图像 2,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 步骤 3 中的图像 3,3
    • Locate where the camera is plugged into the motherboard. It should be on the left side of the motherboard just above the center.
    • Once located lift the black lever on the right side of the connector. This will release the camera.
    • Once the lever is lifted, pull out the camera by gently tugging the cameras connector tape.
    询问修复机器人
    添加评论
  4. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 步骤 4 中的图像 1,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 步骤 4 中的图像 2,3 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove yellow tape that is securing the camera to the back cover.
    • Now take tweezers, and gently grab one of the cameras. Once grabbed, begin to twist to remove from device. Do this for both cameras.
    询问修复机器人
    添加评论
结论
For information you can go to http://www.doublepowertech.com/download/...
取消:我没有完成这个指南。
Kaitlyn Hayes
于01/21/15注册
414 声望
创作了4篇指南
团队
USF Tampa, Team 5-2, Brown Winter 2015 USF Tampa, Team 5-2, Brown Winter 2015 的会员
USFT-BROWN-W15S5G2
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 646
