跳转到主内容
DKnight MagicBox II Button Panel Replacement
你所需要的
  1. DKnight MagicBox II Button Panel Replacement, Front Panel Assembly: 步骤 1 中的图像 1,2 DKnight MagicBox II Button Panel Replacement, Front Panel Assembly: 步骤 1 中的图像 2,2
    • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
  2. DKnight MagicBox II Button Panel Replacement: 步骤 2 中的图像 1,3 DKnight MagicBox II Button Panel Replacement: 步骤 2 中的图像 2,3 DKnight MagicBox II Button Panel Replacement: 步骤 2 中的图像 3,3
    • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
  3. DKnight MagicBox II Button Panel Replacement: 步骤 3 中的图像 1,2 DKnight MagicBox II Button Panel Replacement: 步骤 3 中的图像 2,2
    • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
  4. DKnight MagicBox II Button Panel Replacement: 步骤 4 中的图像 1,2 DKnight MagicBox II Button Panel Replacement: 步骤 4 中的图像 2,2
    • Pull apart the two faces to separate the back panel from the front face plate.
  5. DKnight MagicBox II Button Panel Replacement, Motherboard: 步骤 5 中的图像 1,2 DKnight MagicBox II Button Panel Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
  6. DKnight MagicBox II Button Panel Replacement: 步骤 6 中的图像 1,1
    • Using your fingers gently pry the motherboard loose from the black insulant adhesive
  7. DKnight MagicBox II Button Panel Replacement: 步骤 7 中的图像 1,1
    • Disconnect the Button Panel plug (Largest of the Plugs, it can be traced back to the button panel easily)
  8. DKnight MagicBox II Button Panel Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to push down on the safety prongs on the plastic switch. Then Disconnect the Power Wire plug by hand (Red medium),
  9. DKnight MagicBox II Button Panel Replacement: 步骤 9 中的图像 1,1
    • Use the tweezers to push down on the two safety prongs on the plastic switch. Then Disconnect the two Speaker plug connections by hand (Two Smaller Plugs)
  10. DKnight MagicBox II Button Panel Replacement: 步骤 10 中的图像 1,2 DKnight MagicBox II Button Panel Replacement: 步骤 10 中的图像 2,2
    • The Motherboard is now free from the speaker assembly
  11. DKnight MagicBox II Button Panel Replacement, Button Panel: 步骤 11 中的图像 1,1
    • Remove the three screws holding the button board in place (Screw Head PH1, Size 0.5 cm)
    • You should now be able to remove the button panel from the device.
结论
Anthony
于02/04/16注册
695 声望
创作了3篇指南
团队
USF Tampa, Team 17-1, Blackwell Winter 2016 USF Tampa, Team 17-1, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 942
