跳转到主内容
DJI Spark Controller Mobile Device Grip Replacement
你所需要的
  1. DJI Spark Controller Mobile Device Grip Replacement, Mobile Device Grip: 步骤 1 中的图像 1,1
    • Unfold the arm.
    • Extend the controller’s arm as you would before normally flying the drone.
    • To avoid obstruction, make sure the screwheads of the grip are parallel to the body of the controller.
  2. DJI Spark Controller Mobile Device Grip Replacement: 步骤 2 中的图像 1,3 DJI Spark Controller Mobile Device Grip Replacement: 步骤 2 中的图像 2,3 DJI Spark Controller Mobile Device Grip Replacement: 步骤 2 中的图像 3,3
    • Remove the grip.
    • Remove two screws using a T6 torx screwdriver.
    • Use this same procedure for both arms.
  3. DJI Spark Controller Mobile Device Grip Replacement: 步骤 3 中的图像 1,2 DJI Spark Controller Mobile Device Grip Replacement: 步骤 3 中的图像 2,2
    • Once both screws are removed, the grip parts come off easily.
    • Be carful when doing this step because the two parts of the grip might fall once the two screws are removed.
结论
Amelia Hagberg
于10/21/19注册
415 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 UMass Dartmouth, Team S1-G7, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G7
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 594
