跳转到主内容
加入维修社区 - 创建账户
DJI Phantom Propeller Replacement
你所需要的
  1. DJI Phantom Propeller Replacement, Open the Battery Compartment: 步骤 1 中的图像 1,3 DJI Phantom Propeller Replacement, Open the Battery Compartment: 步骤 1 中的图像 2,3 DJI Phantom Propeller Replacement, Open the Battery Compartment: 步骤 1 中的图像 3,3
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Propeller Replacement, Remove the Battery: 步骤 2 中的图像 1,3 DJI Phantom Propeller Replacement, Remove the Battery: 步骤 2 中的图像 2,3 DJI Phantom Propeller Replacement, Remove the Battery: 步骤 2 中的图像 3,3
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Propeller Replacement, Disconnect the Battery: 步骤 3 中的图像 1,2 DJI Phantom Propeller Replacement, Disconnect the Battery: 步骤 3 中的图像 2,2
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: 步骤 4 中的图像 1,2 DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: 步骤 4 中的图像 2,2
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: 步骤 5 中的图像 1,3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: 步骤 5 中的图像 2,3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: 步骤 5 中的图像 3,3
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. DJI Phantom Propeller Replacement, Unscrewing Black Collets: 步骤 6 中的图像 1,3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: 步骤 6 中的图像 2,3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: 步骤 6 中的图像 3,3
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. DJI Phantom Propeller Replacement, Remove the Propeller: 步骤 7 中的图像 1,3 DJI Phantom Propeller Replacement, Remove the Propeller: 步骤 7 中的图像 2,3 DJI Phantom Propeller Replacement, Remove the Propeller: 步骤 7 中的图像 3,3
    • Gently press down the motor shaft and lift the propeller up to remove it.
结论
David Hoyt
于04/09/10注册
4,053 声望
创作了41篇指南
团队
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G89
4 名成员
创作了61篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 39
总计 1,472
