Lift up on the top portion of the shell and set it on its side.
Do not attempt to fully remove the case. The GPS and Magnetometer cables connect the top shell to the rest of the Phantom, be careful not to stress or break these cables.
Insert the molex connector through one of the landing gear holes and case bottom shell.
Pull the cable through.
This is a really tight fit, take your time and avoid damaging the molex connector or cable. We found that gently rocking the molex connector back and forth through the hole eventually wiggled it through.
