跳转到主内容
加入维修社区 - 创建账户
DJI Phantom 4 Advanced Shell Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. DJI Phantom 4 Advanced Shell Replacement, Propeller: 步骤 1 中的图像 1,2 DJI Phantom 4 Advanced Shell Replacement, Propeller: 步骤 1 中的图像 2,2
    • Use your finger tips to pinch the damaged propeller.
    • Twist the propeller counterclockwise and pull up to remove.
  2. DJI Phantom 4 Advanced Shell Replacement, Shell: 步骤 2 中的图像 1,2 DJI Phantom 4 Advanced Shell Replacement, Shell: 步骤 2 中的图像 2,2
    • Remove the eight 7 mm hex screws by turning counterclockwise with a 2 mm hex bit.
  3. DJI Phantom 4 Advanced Shell Replacement: 步骤 3 中的图像 1,1
    • Pry the LED motor covers off with a metal spudger.
    • The prying location is marked by an indent that points outward from the arm.
  4. DJI Phantom 4 Advanced Shell Replacement: 步骤 4 中的图像 1,1
    • Pry the paper covering off the four corners with a metal spudger.
  5. DJI Phantom 4 Advanced Shell Replacement: 步骤 5 中的图像 1,1
    • Remove the twelve 8.7 mm hex screws with a 2 mm hex bit from the motor bases.
  6. DJI Phantom 4 Advanced Shell Replacement: 步骤 6 中的图像 1,2 DJI Phantom 4 Advanced Shell Replacement: 步骤 6 中的图像 2,2
    • Flip the drone on its back
    • Remove the eight 4.5 mm hex screws by turning them counterclockwise with a 1.5 mm hex bit.
    • Separate the mesh from the drone by pulling up gently and rocking left to right.
    • The cable connects from the camera to the drone. Pulling up could rip the connection. Tilt the mesh 90 degrees towards the cable.
  7. DJI Phantom 4 Advanced Shell Replacement: 步骤 7 中的图像 1,1
    • Remove two 1.2mm screws using the JIS #000 bit from the camera cable retaining bracket.
  8. DJI Phantom 4 Advanced Shell Replacement: 步骤 8 中的图像 1,1
    • Lift the camera connector at one end with your hand and remove the mesh.
  9. DJI Phantom 4 Advanced Shell Replacement: 步骤 9 中的图像 1,3 DJI Phantom 4 Advanced Shell Replacement: 步骤 9 中的图像 2,3 DJI Phantom 4 Advanced Shell Replacement: 步骤 9 中的图像 3,3
    • Remove the two 1.2 mm screws using a JIS #000 bit from the antenna retaining bracket.
    • Pull the four U.FL antennae up.
    • The U.FL antenna connectors are fragile.
    • Remove the two 4 mm screws using a JIS #000 bit.
  10. DJI Phantom 4 Advanced Shell Replacement: 步骤 10 中的图像 1,2 DJI Phantom 4 Advanced Shell Replacement: 步骤 10 中的图像 2,2
    • Pry apart the clamshell at the motor end.
    • Separate the clamshell.
    • Two wires connect from the lower frame to the upper frame at the front of the drone. Pulling the clamshell apart hard may damage the connectors and wires.
  11. DJI Phantom 4 Advanced Shell Replacement: 步骤 11 中的图像 1,1
    • Press the connector tabs with a spudger and pull on the wire simultaneously.
    • Remove the shell from the rest of the drone.
结论
另外一个人完成了本指南。
David Hudson
于10/08/18注册
301 声望
创作了2篇指南
团队
Cal Poly, Team S15-G6, White Fall 2018 Cal Poly, Team S15-G6, White Fall 2018 的会员
CPSU-WHITE-F18S15G6
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 123
