跳转到主内容
DJI Phantom 4 Advanced Remote Controller Power Button Replacement
你所需要的
  1. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 2 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 2 中的图像 2,2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 3 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 3 中的图像 2,2
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 4 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 4 中的图像 2,2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 5 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 5 中的图像 2,2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 步骤 6 中的图像 1,3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 步骤 6 中的图像 2,3 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 7 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 7 中的图像 2,2
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 8 中的图像 1,1
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: 步骤 9 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement, Power Button: 步骤 9 中的图像 2,2
    • Carefully remove the plastic. This will help you gain access to the power button panel.
  10. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 10 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 10 中的图像 2,2
    • With a Phillips #00 screwdriver, remove the two screws on the power button panel.
  11. DJI Phantom 4 Advanced Remote Controller Power Button Replacement: 步骤 11 中的图像 1,1
    • Gently pull the power button out from the panel. Replace it with a new one.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 844
