跳转到主内容
加入维修社区 - 创建账户
DJI Phantom 4 Advanced Remote Controller Back Panel Replacement
你所需要的
  1. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 2 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 2 中的图像 2,2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 3 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 4 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 4 中的图像 2,2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 5 中的图像 1,2 DJI Phantom 4 Advanced Remote Controller Back Panel Replacement: 步骤 5 中的图像 2,2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 963
