跳转到主内容
DJI Phantom 3 Standard Remote Controller Joysticks Replacement
你所需要的
  1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: 步骤 1 中的图像 1,2 DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: 步骤 1 中的图像 2,2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 步骤 2 中的图像 1,1
    • On the inside of the controller, remove the four 11 mm screws that cover the base housing of the joystick.
  3. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 步骤 3 中的图像 1,3 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 步骤 3 中的图像 2,3 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 步骤 3 中的图像 3,3
    • Inside the base housing, remove the two 9 mm screws that secure the joystick brace piece on both the left and right side of the stick.
    • Remove the braces on the left and right sides of the joystick to reach the circuit board piece on the left.
    • Detach the circuit board piece.
  4. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 步骤 4 中的图像 1,2 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 步骤 4 中的图像 2,2
    • Separate the other circuit board piece from the joystick connection using a plastic spudger.
    • The circuit board is wired through glue. If the plastic spudger is unable to pry the glue off, use the metal spudger as a last resort.
    • Take the joystick module itself and remove the four 8 mm screws that connect the joystick to the housing.
    • Unscrew the thumb stick from the module if a replacement is not needed.
  5. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 步骤 5 中的图像 1,1
    • Remove the joystick.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 200
