跳转到主内容
DJI Phantom 3 Standard Remote Controller Battery Replacement
你所需要的
  1. DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: 步骤 1 中的图像 1,2 DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a Phillips #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Battery Replacement: 步骤 2 中的图像 1,2 DJI Phantom 3 Standard Remote Controller Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the two 8 mm screws securing the battery to the controller using a JIS #00 screwdriver.
  3. DJI Phantom 3 Standard Remote Controller Battery Replacement: 步骤 3 中的图像 1,3 DJI Phantom 3 Standard Remote Controller Battery Replacement: 步骤 3 中的图像 2,3 DJI Phantom 3 Standard Remote Controller Battery Replacement: 步骤 3 中的图像 3,3
    • Use the nylon-tipped tweezers to detach the three-prong battery attachment that connects the battery to the motherboard.
    • Remove the battery.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 48
总计 544
