跳转到主内容
DJI Phantom 3 Standard Remote Controller Antenna Replacement
你所需要的
  1. DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: 步骤 1 中的图像 1,2 DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: 步骤 1 中的图像 2,2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Antenna Replacement: 步骤 2 中的图像 1,2 DJI Phantom 3 Standard Remote Controller Antenna Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry the gray antenna wire from the glue.
    • There is a small metal piece latched in and should be removed from its place as well.
    • While a plastic spudger can be used, the attachment is secure. A metal spudger may produce better results.
  3. DJI Phantom 3 Standard Remote Controller Antenna Replacement: 步骤 3 中的图像 1,1
    • Push the wire up to the antenna.
  4. DJI Phantom 3 Standard Remote Controller Antenna Replacement: 步骤 4 中的图像 1,1
    • Squeeze and twist the outer antenna attachment to unlatch it from its place.
    • Remove the antenna.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 379
