跳转到主内容
DJI Phantom 3 Advanced Landing Gear Replacement
你所需要的
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: 步骤 1 中的图像 1,2 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: 步骤 1 中的图像 2,2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 2 中的图像 1,2 DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 2 中的图像 2,2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 步骤 3 中的图像 1,3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 步骤 3 中的图像 2,3 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: 步骤 3 中的图像 3,3
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 4 中的图像 1,3 DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 4 中的图像 2,3 DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 4 中的图像 3,3
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 5 中的图像 1,3 DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 5 中的图像 2,3 DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 5 中的图像 3,3
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 6 中的图像 1,3 DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 6 中的图像 2,3 DJI Phantom 3 Advanced Landing Gear Replacement: 步骤 6 中的图像 3,3
    • Feed the wire and attached plastic through the hole in the landing gear.
结论
7等其他人完成本指南。
Quinn Tirpak
于10/06/16注册
319 声望
创作了2篇指南
团队
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G2
3 名成员
创作了12篇指南
一条评论
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 14
总计 3,806
