跳转到主内容
DJI Phantom 2 Vision+ Propellers Removal
你所需要的
  1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 步骤 1 中的图像 1,3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 步骤 1 中的图像 2,3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: 步骤 1 中的图像 3,3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ Propellers Removal, Propellers: 步骤 2 中的图像 1,1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 步骤 3 中的图像 1,3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 步骤 3 中的图像 2,3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: 步骤 3 中的图像 3,3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 步骤 4 中的图像 1,3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 步骤 4 中的图像 2,3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: 步骤 4 中的图像 3,3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
结论
4等其他人完成本指南。
David Hoyt
于04/09/10注册
4,023 声望
创作了43篇指南
团队
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G89
4 名成员
创作了63篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 7,077
