跳转到主内容
DJI Phantom 2 Vision+ Battery Removal
  1. DJI Phantom 2 Vision+ Battery Removal, Remove the battery: 步骤 1 中的图像 1,3 DJI Phantom 2 Vision+ Battery Removal, Remove the battery: 步骤 1 中的图像 2,3 DJI Phantom 2 Vision+ Battery Removal, Remove the battery: 步骤 1 中的图像 3,3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
结论
3等其他人完成本指南。
David Hoyt
于04/09/10注册
4,023 声望
创作了43篇指南
团队
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G89
4 名成员
创作了63篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 17
总计 2,256
