跳转到主内容
DJI Mini 2 Drone Body Replacement
你所需要的
  1. DJI Mini 2 Drone Body Replacement, Battery: 步骤 1 中的图像 1,2 DJI Mini 2 Drone Body Replacement, Battery: 步骤 1 中的图像 2,2
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
  2. DJI Mini 2 Drone Body Replacement: 步骤 2 中的图像 1,2 DJI Mini 2 Drone Body Replacement: 步骤 2 中的图像 2,2
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
  3. DJI Mini 2 Drone Body Replacement, Drone Body: 步骤 3 中的图像 1,2 DJI Mini 2 Drone Body Replacement, Drone Body: 步骤 3 中的图像 2,2
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  4. DJI Mini 2 Drone Body Replacement: 步骤 4 中的图像 1,2 DJI Mini 2 Drone Body Replacement: 步骤 4 中的图像 2,2
    • Remove the four 5 mm J000 screws near each propeller arm.
  5. DJI Mini 2 Drone Body Replacement: 步骤 5 中的图像 1,3 DJI Mini 2 Drone Body Replacement: 步骤 5 中的图像 2,3 DJI Mini 2 Drone Body Replacement: 步骤 5 中的图像 3,3
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
  6. DJI Mini 2 Drone Body Replacement: 步骤 6 中的图像 1,2 DJI Mini 2 Drone Body Replacement: 步骤 6 中的图像 2,2
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
  7. DJI Mini 2 Drone Body Replacement: 步骤 7 中的图像 1,2 DJI Mini 2 Drone Body Replacement: 步骤 7 中的图像 2,2
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
结论
6等其他人完成本指南。
Jacob Matos
于03/25/22注册
1,083 声望
创作了4篇指南
团队
UMass Dartmouth, Team F-1, Gurgel Spring 2022 UMass Dartmouth, Team F-1, Gurgel Spring 2022 的会员
UMASSD-GURGEL-S22SFG1
2 名成员
创作了15篇指南
2条评论
Where to buy a new drone body ?
Loïc Sarda - 回复
Same Q. Where to buy drone body? Please email me. Thanks
Ruud - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 46
过去 30 天: 211
总计 5,427
