跳转到主内容
DJI Mavic Pro Upper Shell Replacement
你所需要的
  1. DJI Mavic Pro Upper Shell Replacement, Battery: 步骤 1 中的图像 1,3 DJI Mavic Pro Upper Shell Replacement, Battery: 步骤 1 中的图像 2,3 DJI Mavic Pro Upper Shell Replacement, Battery: 步骤 1 中的图像 3,3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Upper Shell Replacement, Upper Shell: 步骤 2 中的图像 1,1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Upper Shell Replacement: 步骤 3 中的图像 1,1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Upper Shell Replacement: 步骤 4 中的图像 1,1
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Upper Shell Replacement: 步骤 5 中的图像 1,1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Upper Shell Replacement: 步骤 6 中的图像 1,1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Upper Shell Replacement: 步骤 7 中的图像 1,1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
结论
6等其他人完成本指南。
Mondona Behroozian
于10/08/18注册
1,552 声望
创作了2篇指南
团队
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018 的会员
CPSU-WHITE-F18S17G3
4 名成员
创作了14篇指南
2条评论
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - 回复
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 5,167
