跳转到主内容
DJI Mavic Pro Front Vision Replacement
你所需要的
  1. DJI Mavic Pro Front Vision Replacement, Battery: 步骤 1 中的图像 1,3 DJI Mavic Pro Front Vision Replacement, Battery: 步骤 1 中的图像 2,3 DJI Mavic Pro Front Vision Replacement, Battery: 步骤 1 中的图像 3,3
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Front Vision Replacement, Upper Shell: 步骤 2 中的图像 1,1
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Front Vision Replacement: 步骤 3 中的图像 1,1
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Front Vision Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Front Vision Replacement: 步骤 5 中的图像 1,1
    • Remove the six 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  6. DJI Mavic Pro Front Vision Replacement: 步骤 6 中的图像 1,1
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Front Vision Replacement: 步骤 7 中的图像 1,1
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro Front Vision Replacement, Gimbal/Camera: 步骤 8 中的图像 1,1
    • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
  9. DJI Mavic Pro Front Vision Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
  10. DJI Mavic Pro Front Vision Replacement: 步骤 10 中的图像 1,2 DJI Mavic Pro Front Vision Replacement: 步骤 10 中的图像 2,2
    • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
    • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
  11. DJI Mavic Pro Front Vision Replacement: 步骤 11 中的图像 1,1
    • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
  12. DJI Mavic Pro Front Vision Replacement: 步骤 12 中的图像 1,2 DJI Mavic Pro Front Vision Replacement: 步骤 12 中的图像 2,2
    • Flip the DJI Mavic Pro over.
    • Gently press the latch for the Gimbal cover.
    • Pull the cover off.
  13. DJI Mavic Pro Front Vision Replacement: 步骤 13 中的图像 1,2 DJI Mavic Pro Front Vision Replacement: 步骤 13 中的图像 2,2
    • Flip the DJI Mavic Pro back over, with its top side facing up.
    • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
  14. DJI Mavic Pro Front Vision Replacement: 步骤 14 中的图像 1,1
    • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
  15. DJI Mavic Pro Front Vision Replacement: 步骤 15 中的图像 1,1
    • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
    • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
  16. DJI Mavic Pro Front Vision Replacement: 步骤 16 中的图像 1,1
    • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
    • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
  17. DJI Mavic Pro Front Vision Replacement: 步骤 17 中的图像 1,2 DJI Mavic Pro Front Vision Replacement: 步骤 17 中的图像 2,2
    • Flip the DJI Mavic Pro over, with the camera facing you.
    • Gently pull the gimbal/camera assembly up and out.
  18. DJI Mavic Pro Front Vision Replacement, Front Vision: 步骤 18 中的图像 1,1
    • Remove the two 6mm JIS #0 screws by turning counterclockwise.
  19. DJI Mavic Pro Front Vision Replacement: 步骤 19 中的图像 1,1
    • Remove the front vision piece by pulling the piece up and away from the drone body.
结论
7等其他人完成本指南。
Kyle Kelser
于10/08/18注册
598 声望
创作了2篇指南
团队
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018 的会员
CPSU-WHITE-F18S17G3
4 名成员
创作了14篇指南
一条评论
What error codes did you get before having to replace this front cameras?
Daniel Rubio Rocamora - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 57
总计 6,824
