简介
This guide will illustrate how to change your "DJI Mavic 2 Pro" battery. If the device is experiencing power-related issues, it may be caused by problems with the battery. Please ensure your device is powered off and disconnected from any external power source before beginning. The process is simple and should not take much time. There will be no tools needed.
你所需要的
Press the buttons on the sides of the drone and pull the battery upwards from the drone to remove it.
Set aside and charge dead battery.
Ensure the battery is secured in place.
This is not actually helpful as putting an charged battery on any dji is self explanatory. If you wanna provide good and usable content try doing a diy on the replacement of the remote battery for a DJI Mavic 2 Pro and providing a valid source for this replacement battery. Thanks in advance.
I took 1 person AND 9 contributors to write this?
If all directions are followed, you have successfully replaced your DJI Mavic 2 Pro battery.
另外一个人完成了本指南。
La batería no carga
Carlos Giraldo - 回复
