跳转到主内容
DBPOWER T20 Speaker Replacement
你所需要的
  1. DBPOWER T20 Speaker Replacement, DBPOWER T20 Disassembly: 步骤 1 中的图像 1,1
    • Flip the device and lay flat.
  2. DBPOWER T20 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Speaker Replacement: 步骤 3 中的图像 1,3 DBPOWER T20 Speaker Replacement: 步骤 3 中的图像 2,3 DBPOWER T20 Speaker Replacement: 步骤 3 中的图像 3,3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Speaker Replacement: 步骤 5 中的图像 1,2 DBPOWER T20 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Speaker Replacement: 步骤 6 中的图像 1,3 DBPOWER T20 Speaker Replacement: 步骤 6 中的图像 2,3 DBPOWER T20 Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Speaker Replacement: 步骤 7 中的图像 1,2 DBPOWER T20 Speaker Replacement: 步骤 7 中的图像 2,2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Speaker Replacement: 步骤 8 中的图像 1,1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Speaker Replacement: 步骤 9 中的图像 1,2 DBPOWER T20 Speaker Replacement: 步骤 9 中的图像 2,2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Speaker Replacement: 步骤 10 中的图像 1,2 DBPOWER T20 Speaker Replacement: 步骤 10 中的图像 2,2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Speaker Replacement, Speaker: 步骤 11 中的图像 1,2 DBPOWER T20 Speaker Replacement, Speaker: 步骤 11 中的图像 2,2
    • Remove the two (3 mm) screws connecting the bracket down and pull out the reflector, using a J0 Philips Head Screwdriver.
  12. DBPOWER T20 Speaker Replacement: 步骤 12 中的图像 1,3 DBPOWER T20 Speaker Replacement: 步骤 12 中的图像 2,3 DBPOWER T20 Speaker Replacement: 步骤 12 中的图像 3,3
    • Slide the mirror straight up to remove.
  13. DBPOWER T20 Speaker Replacement: 步骤 13 中的图像 1,3 DBPOWER T20 Speaker Replacement: 步骤 13 中的图像 2,3 DBPOWER T20 Speaker Replacement: 步骤 13 中的图像 3,3
    • Slide out the power source and disconnect its cables from the power jack and the light.
  14. DBPOWER T20 Speaker Replacement: 步骤 14 中的图像 1,3 DBPOWER T20 Speaker Replacement: 步骤 14 中的图像 2,3 DBPOWER T20 Speaker Replacement: 步骤 14 中的图像 3,3
    • Remove the screws holding down the first speaker with a J0 screwdriver.
    • Remove the screws holding down the second speaker down.
结论
2等其他人完成本指南。
Ryan Goldin
于02/15/18注册
245 声望
撰写一个指南
团队
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 455
