跳转到主内容
DBPOWER T20 Lens Replacement
你所需要的
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: 步骤 1 中的图像 1,1
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: 步骤 3 中的图像 1,3 DBPOWER T20 Lens Replacement: 步骤 3 中的图像 2,3 DBPOWER T20 Lens Replacement: 步骤 3 中的图像 3,3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lens Replacement: 步骤 5 中的图像 1,2 DBPOWER T20 Lens Replacement: 步骤 5 中的图像 2,2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lens Replacement: 步骤 6 中的图像 1,3 DBPOWER T20 Lens Replacement: 步骤 6 中的图像 2,3 DBPOWER T20 Lens Replacement: 步骤 6 中的图像 3,3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: 步骤 7 中的图像 1,2 DBPOWER T20 Lens Replacement: 步骤 7 中的图像 2,2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lens Replacement: 步骤 8 中的图像 1,1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lens Replacement: 步骤 9 中的图像 1,2 DBPOWER T20 Lens Replacement: 步骤 9 中的图像 2,2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: 步骤 10 中的图像 1,2 DBPOWER T20 Lens Replacement: 步骤 10 中的图像 2,2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: 步骤 11 中的图像 1,1
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: 步骤 12 中的图像 1,1
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: 步骤 13 中的图像 1,1
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: 步骤 14 中的图像 1,2 DBPOWER T20 Lens Replacement: 步骤 14 中的图像 2,2
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: 步骤 15 中的图像 1,1
    • Remove the focus-adjustment ring from the lens housing.
结论
4等其他人完成本指南。
Andrea Espinosa
于02/15/18注册
521 声望
创作了3篇指南
团队
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G2
5 名成员
创作了5篇指南
3指南评论
How does the lens parts go together?
Lay - 回复
I need to know the same
Tremaine Mullins - 回复
Trying to put my lens back how to install
David Williams - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 2,692
