跳转到主内容
DBPOWER T20 Lamp Replacement
你所需要的
  1. DBPOWER T20 Lamp Replacement, DBPOWER T20 Disassembly: 步骤 1 中的图像 1,1
    • Flip the device and lay flat.
  2. DBPOWER T20 Lamp Replacement: 步骤 2 中的图像 1,1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lamp Replacement: 步骤 3 中的图像 1,3 DBPOWER T20 Lamp Replacement: 步骤 3 中的图像 2,3 DBPOWER T20 Lamp Replacement: 步骤 3 中的图像 3,3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lamp Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lamp Replacement: 步骤 5 中的图像 1,2 DBPOWER T20 Lamp Replacement: 步骤 5 中的图像 2,2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lamp Replacement: 步骤 6 中的图像 1,3 DBPOWER T20 Lamp Replacement: 步骤 6 中的图像 2,3 DBPOWER T20 Lamp Replacement: 步骤 6 中的图像 3,3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lamp Replacement: 步骤 7 中的图像 1,2 DBPOWER T20 Lamp Replacement: 步骤 7 中的图像 2,2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lamp Replacement: 步骤 8 中的图像 1,1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lamp Replacement: 步骤 9 中的图像 1,2 DBPOWER T20 Lamp Replacement: 步骤 9 中的图像 2,2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lamp Replacement: 步骤 10 中的图像 1,2 DBPOWER T20 Lamp Replacement: 步骤 10 中的图像 2,2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lamp Replacement, Lamp: 步骤 11 中的图像 1,1
    • Remove the two screws attached to the lamp with a J0 screwdriver.
  12. DBPOWER T20 Lamp Replacement: 步骤 12 中的图像 1,1
    • Lift upwards to remove the lamp.
结论
4等其他人完成本指南。
Andrea Espinosa
于02/15/18注册
506 声望
创作了3篇指南
团队
USF Tampa, Team S16-G2, Boczar Spring 2018 USF Tampa, Team S16-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G2
5 名成员
创作了5篇指南
6条评论
where can I get the replacement lamp?
David Rug - 回复
The part that is being removed is NOT the LED lamp. My interest is replacing the actual LED lamp that sits behind the plastic part that is being removed. My projector image started to have a tan cast to it near the top left portion of the screen due to overheating. I am just assuming that it is the actual LED that is overheating and need replacing. The article is very good otherwise. Please add where replacement parts can be obtained.
m patn - 回复
Thank you very much, I appreciate the ability to get a look without having to open it up
Luke e Savage - 回复
Where can i buy the lamp?
Keshawn Buckner - 回复
Merci pour ce tuto! =) ça ma permis de nettoyer la lentille qui était pleine de poussière!
Jules Schminke - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 30
总计 3,923
