跳转到主内容
DBPOWER RD-810 Lens Replacement
你所需要的
  1. DBPOWER RD-810 Lens Replacement, Top Cover: 步骤 1 中的图像 1,2 DBPOWER RD-810 Lens Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Lens Replacement: 步骤 2 中的图像 1,1
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: 步骤 3 中的图像 1,3 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: 步骤 3 中的图像 2,3 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: 步骤 3 中的图像 3,3
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Lens Replacement: 步骤 4 中的图像 1,3 DBPOWER RD-810 Lens Replacement: 步骤 4 中的图像 2,3 DBPOWER RD-810 Lens Replacement: 步骤 4 中的图像 3,3
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Lens Replacement: 步骤 5 中的图像 1,3 DBPOWER RD-810 Lens Replacement: 步骤 5 中的图像 2,3 DBPOWER RD-810 Lens Replacement: 步骤 5 中的图像 3,3
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Lens Replacement, Power Supply Circuit: 步骤 6 中的图像 1,3 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: 步骤 6 中的图像 2,3 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: 步骤 6 中的图像 3,3
    • Remove the two 9mm PH2 phillips head screws.
    • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
  7. DBPOWER RD-810 Lens Replacement: 步骤 7 中的图像 1,2 DBPOWER RD-810 Lens Replacement: 步骤 7 中的图像 2,2
    • Lift the power supply circuit board out of the projector.
    • Disconnect the cable connector by pulling the two sides of the connector apart.
    • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
  8. DBPOWER RD-810 Lens Replacement, Lens: 步骤 8 中的图像 1,3 DBPOWER RD-810 Lens Replacement, Lens: 步骤 8 中的图像 2,3 DBPOWER RD-810 Lens Replacement, Lens: 步骤 8 中的图像 3,3
    • Flip the projector over and remove the two 6mm PH2 phillips head screws.
    • Flip the projector over so that the opening is facing up.
    • Lift the lens up slightly and then move it towards the interior of the projector before lifting it up and out of the way.
结论
另外一个人完成了本指南。
John Russell
于02/14/18注册
914 声望
创作了9篇指南
团队
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G3
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 498
