跳转到主内容
D5 Pump Impeller Replacement
你所需要的
  1. D5 Pump Impeller Replacement, Impeller: 步骤 1 中的图像 1,2 D5 Pump Impeller Replacement, Impeller: 步骤 1 中的图像 2,2
    • Drain your water-cooling loop and disconnect any fittings.
    • Grasp the retaining ring and twist counter-clockwise to free the pump from the housing.
  2. D5 Pump Impeller Replacement: 步骤 2 中的图像 1,2 D5 Pump Impeller Replacement: 步骤 2 中的图像 2,2
    • After the pump has been removed, grasp the impeller and rotate it. If it has any resistance, a replacement is necessary.
    • Firmly hold the impeller and pull. It will take some force to remove.
  3. D5 Pump Impeller Replacement: 步骤 3 中的图像 1,2 D5 Pump Impeller Replacement: 步骤 3 中的图像 2,2
    • After the impeller has been removed, use a cloth to clean any debris.
    • Use a cotton swab to clean any gunk or residue from tight spaces.
    • Not cleaning the pump before installing a new impeller can cause it to fail.
  4. D5 Pump Impeller Replacement: 步骤 4 中的图像 1,1
    • Place the new impeller into the pump body by dropping it in. This doesn't require any force.
  5. D5 Pump Impeller Replacement: 步骤 5 中的图像 1,1
    • Manually test your impeller by pressing down and rotating it.
    • If there is any resistance, turning it on could damage the new impeller. Ensure that it was thoroughly cleaned.
  6. D5 Pump Impeller Replacement: 步骤 6 中的图像 1,1
    • Visually inspect your impeller. It should be parallel to the pump.
    • If the impeller is lopsided, remove it and ensure that there is no debris blocking the installation.
结论
To reassemble your device, follow the first step in reverse.
James Gibson
于10/28/20注册
133 声望
撰写一个指南
团队
Texas Tech, Team S14-G3, Cowan Fall 2020 Texas Tech, Team S14-G3, Cowan Fall 2020 的会员
TTU-COWAN-F20S14G3
1 名成员
创作了1篇指南
4条评论
Wow, that was useless. I mean it’s pretty obvious and straightforward process. If you are capable of assembling the loop, you are more than capable of replacing the impeller without any guide. The question is where can one find a new impeller, but ofc this useless guide won’t tell you.
Angry Beaver - 回复
Have not found one place selling impellers other then AliExpress but after shipping and everything you might as well buy a whole pump unit and have a warranty.
JMan31337 - 回复
What angry beaver said.
Mindbulletz - 回复
Sam Weiler - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 61
总计 3,342
