跳转到主内容
加入维修社区 - 创建账户
D-Link HD Wi-Fi Camera LED Lights Replacement
你所需要的
  1. D-Link HD Wi-Fi Camera LED Lights Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera LED Lights Replacement: 步骤 2 中的图像 1,2 D-Link HD Wi-Fi Camera LED Lights Replacement: 步骤 2 中的图像 2,2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera LED Lights Replacement: 步骤 3 中的图像 1,2 D-Link HD Wi-Fi Camera LED Lights Replacement: 步骤 3 中的图像 2,2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera LED Lights Replacement, Microphone: 步骤 4 中的图像 1,1
    • To remove the front cover, place index finger in the center and pull away from the frame. This may take a little effort, but should not require an opening tool.
  5. D-Link HD Wi-Fi Camera LED Lights Replacement: 步骤 5 中的图像 1,2 D-Link HD Wi-Fi Camera LED Lights Replacement: 步骤 5 中的图像 2,2
    • After the cover is removed, unscrew the two Phillips #00 5.0mm screws. Then the board should slide right out.
  6. D-Link HD Wi-Fi Camera LED Lights Replacement, LED Lights: 步骤 6 中的图像 1,1
    • There are two lights, one on either side of the board.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 642
