跳转到主内容
加入维修社区 - 创建账户
D-Link HD Wi-Fi Camera Camera Lens Replacement
你所需要的
  1. D-Link HD Wi-Fi Camera Camera Lens Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Camera Lens Replacement: 步骤 2 中的图像 1,2 D-Link HD Wi-Fi Camera Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Camera Lens Replacement: 步骤 3 中的图像 1,2 D-Link HD Wi-Fi Camera Camera Lens Replacement: 步骤 3 中的图像 2,2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: 步骤 4 中的图像 1,2 D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: 步骤 4 中的图像 2,2
    • Make sure your hands are dry and you are working in a dry area. To prevent damage, do not touch the lens.
    • There are two Phillips #00 6.0mm screws keeping the camera in place. Remove the screws first.
    • Gently unplug the camera from the motherboard, and remove the camera.
结论
1指南评论
How do I get hold of a replacement lens? Can’t seem to find anyone selling them. Need one for a DCS-2670L
Paul Williams - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 58
总计 1,601
