跳转到主内容
D-Link DIR-890L Motherboard Replacement
你所需要的
  1. D-Link DIR-890L Motherboard  Replacement, Case: 步骤 1 中的图像 1,3 D-Link DIR-890L Motherboard  Replacement, Case: 步骤 1 中的图像 2,3 D-Link DIR-890L Motherboard  Replacement, Case: 步骤 1 中的图像 3,3
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Motherboard  Replacement: 步骤 2 中的图像 1,3 D-Link DIR-890L Motherboard  Replacement: 步骤 2 中的图像 2,3 D-Link DIR-890L Motherboard  Replacement: 步骤 2 中的图像 3,3
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Motherboard  Replacement: 步骤 3 中的图像 1,3 D-Link DIR-890L Motherboard  Replacement: 步骤 3 中的图像 2,3 D-Link DIR-890L Motherboard  Replacement: 步骤 3 中的图像 3,3
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Motherboard  Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Motherboard  Replacement: 步骤 5 中的图像 1,3 D-Link DIR-890L Motherboard  Replacement: 步骤 5 中的图像 2,3 D-Link DIR-890L Motherboard  Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
  6. D-Link DIR-890L Motherboard  Replacement: 步骤 6 中的图像 1,2 D-Link DIR-890L Motherboard  Replacement: 步骤 6 中的图像 2,2
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Motherboard  Replacement: 步骤 7 中的图像 1,3 D-Link DIR-890L Motherboard  Replacement: 步骤 7 中的图像 2,3 D-Link DIR-890L Motherboard  Replacement: 步骤 7 中的图像 3,3
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Motherboard  Replacement: 步骤 8 中的图像 1,3 D-Link DIR-890L Motherboard  Replacement: 步骤 8 中的图像 2,3 D-Link DIR-890L Motherboard  Replacement: 步骤 8 中的图像 3,3
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Motherboard  Replacement: 步骤 9 中的图像 1,2 D-Link DIR-890L Motherboard  Replacement: 步骤 9 中的图像 2,2
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
结论
3等其他人完成本指南。
Rachel Shaw
于10/06/16注册
553 声望
创作了5篇指南
团队
Cal Poly, Team 10-7, Livingston Fall 2016 Cal Poly, Team 10-7, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G7
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 21
总计 2,543
