跳转到主内容
D-Link DCS-825L LED Light Cover Replacement
你所需要的
  1. D-Link DCS-825L LED Light Cover Replacement, Accent Ring: 步骤 1 中的图像 1,1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L LED Light Cover Replacement: 步骤 2 中的图像 1,1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L LED Light Cover Replacement: 步骤 3 中的图像 1,1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L LED Light Cover Replacement, Back Casing: 步骤 4 中的图像 1,2 D-Link DCS-825L LED Light Cover Replacement, Back Casing: 步骤 4 中的图像 2,2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L LED Light Cover Replacement: 步骤 5 中的图像 1,3 D-Link DCS-825L LED Light Cover Replacement: 步骤 5 中的图像 2,3 D-Link DCS-825L LED Light Cover Replacement: 步骤 5 中的图像 3,3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L LED Light Cover Replacement: 步骤 6 中的图像 1,2 D-Link DCS-825L LED Light Cover Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L LED Light Cover Replacement: 步骤 7 中的图像 1,3 D-Link DCS-825L LED Light Cover Replacement: 步骤 7 中的图像 2,3 D-Link DCS-825L LED Light Cover Replacement: 步骤 7 中的图像 3,3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
  8. D-Link DCS-825L LED Light Cover Replacement, LED Light Cover: 步骤 8 中的图像 1,1
    • Grab the white cylinder with your thumb and index finger.
  9. D-Link DCS-825L LED Light Cover Replacement: 步骤 9 中的图像 1,1
    • Gently lift the cylinder up from its placement in your Wi-Fi Baby Camera.
  10. D-Link DCS-825L LED Light Cover Replacement: 步骤 10 中的图像 1,1
    • Remove the white cylinder completely to replace it.
结论
Annalise Leclair
于10/09/18注册
97 声望
撰写一个指南
团队
USF Tampa, Team S1-G5, Leahy Fall 2018 USF Tampa, Team S1-G5, Leahy Fall 2018 的会员
USFT-LEAHY-F18S1G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 317
