跳转到主内容
D-Link DCS-5222L Lens Replacement
你所需要的
  1. D-Link DCS-5222L Lens Replacement, Lens: 步骤 1 中的图像 1,3 D-Link DCS-5222L Lens Replacement, Lens: 步骤 1 中的图像 2,3 D-Link DCS-5222L Lens Replacement, Lens: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the four rubber feet with tweezers to access the screws.
    • Remove all four 7mm screws by using a #1 Phillips screwdriver.
    • Then, with your hands, pull off the lower part of the camera body.
  2. D-Link DCS-5222L Lens Replacement: 步骤 2 中的图像 1,3 D-Link DCS-5222L Lens Replacement: 步骤 2 中的图像 2,3 D-Link DCS-5222L Lens Replacement: 步骤 2 中的图像 3,3
    • On the base motherboard, there are five connecting cables. Disconnect all of them from the motherboard gently using safety tweezers.
    • Do not cut or damage the cables.
    • Disconnecting the antenna cable from motherboard is not necessary.
  3. D-Link DCS-5222L Lens Replacement: 步骤 3 中的图像 1,3 D-Link DCS-5222L Lens Replacement: 步骤 3 中的图像 2,3 D-Link DCS-5222L Lens Replacement: 步骤 3 中的图像 3,3
    • Remove the two 7mm screws holding the motor using a #1 Phillips screwdriver.
    • Pull off the motor and lift away the midbody of the camera using your hands.
  4. D-Link DCS-5222L Lens Replacement: 步骤 4 中的图像 1,2 D-Link DCS-5222L Lens Replacement: 步骤 4 中的图像 2,2
    • Separate the black camera shroud from the upper body by prying loose the tabs with a plastic opening tool or spudger.
    • Use your hands to wiggle the shroud free.
  5. D-Link DCS-5222L Lens Replacement: 步骤 5 中的图像 1,3 D-Link DCS-5222L Lens Replacement: 步骤 5 中的图像 2,3 D-Link DCS-5222L Lens Replacement: 步骤 5 中的图像 3,3
    • Use a #1 Phillips screwdriver to unscrew the four 5mm screws on both sides of the black camera housing to separate it from white body.
    • Unscrew the two 7mm #1 Phillips screws on both sides of the camera housing to open it.
  6. D-Link DCS-5222L Lens Replacement: 步骤 6 中的图像 1,3 D-Link DCS-5222L Lens Replacement: 步骤 6 中的图像 2,3 D-Link DCS-5222L Lens Replacement: 步骤 6 中的图像 3,3
    • Gently disconnect the three cables from the small motherboard using safety tweezers.
    • Use a #0 Phillips screwdriver to remove the two black 2mm screws and a #1 Phillips screwdriver to remove the 2 silver 6mm screws.
    • Separate the board from the black housing.
  7. D-Link DCS-5222L Lens Replacement: 步骤 7 中的图像 1,3 D-Link DCS-5222L Lens Replacement: 步骤 7 中的图像 2,3 D-Link DCS-5222L Lens Replacement: 步骤 7 中的图像 3,3
    • Using your fingers, remove the focus adjustment ring.
    • Twist the lens to unscrew it from the camera module.
    • Replace the broken lens with new one and reassemble all parts of the camera respectively.
结论
另外一个人完成了本指南。
Atefeh Rahmani
于10/27/18注册
172 声望
撰写一个指南
团队
UMass Dartmouth, Team S2-G5, Peak Fall 2018 UMass Dartmouth, Team S2-G5, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 979
