跳转到主内容
加入维修社区 - 创建账户
D-Link HD Wi-Fi Camera Motherboard Replacement
你所需要的
  1. D-Link   HD Wi-Fi Camera Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
    询问修复机器人
    添加评论
  2. D-Link   HD Wi-Fi Camera Motherboard Replacement: 步骤 2 中的图像 1,2 D-Link   HD Wi-Fi Camera Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
    添加评论
  3. D-Link   HD Wi-Fi Camera Motherboard Replacement: 步骤 3 中的图像 1,2 D-Link   HD Wi-Fi Camera Motherboard Replacement: 步骤 3 中的图像 2,2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
1指南评论
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
Azlin Rahim - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 53
总计 1,225
