简介
Use this guide to assist with general disassembly or troubleshooting of your braille display.
配件
无需配件。
  1. Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
    • Remove the plastic cover, paper and chipset.
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  5. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
    • Remove the four screws with a Phillips #00 screwdriver.
  6. Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
    • Remove the connector delicately.
  7. when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
    • when you put it back together make sure mechanical cells are connected correctly
结论
Sisyphe
于2013年07月29日注册
332 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 21
总计 525
